5efe & 5ehfe?
Jamesb4uk
How different are the FE & FHE?
will i be able to use UK spec parts on the FHE? stuff like induction kits, cam belts & other bits & pieces?
I know they have different compresion ratio's but other than that im clueless on the differances
J
i think its possible to use any tuning bit ment fo the fe engine onto the fhe,
generally speaking many service parts - air filter, prob. belt and oil filter will be common.
Rotor arms are different.
Tuning parts - no - some are vehicle dependent - eg an induction kit for a Cynos may not fit a Sera, not because they're the same engine, but due to the space in the engine bay.
The 5E-FHE has a number of uprated components, that may already be superior in standard form than a tuning part for a 5E-FE.
Andrew
Andrew
Interesting idea, any examples?
Sorry to keep picking your brains Andrew but you do know your stuff!! :D :thumbsup:
The 5E-FHE has superior cams for example, and larger injectors, and I believe a superior design of inlet manifold.
Yep, and depending on the year 5efhe, the pistons are actually more like the 4efte and the head is a bit different too. But most major service parts can be exchanged.
