Oil
Corolla_liftback
was looking for advice on best oil to buy for my t sport?
was thinking Castrol magnatec 10 - 30?
any advice appreciated
Shell Helix is pretty good. I've used 5W 30 in my last few cars because I'm reliably informed that 10W 40 is too thick for the UK. 5W 30 will circulate faster (therefore offering better protection on cold starts) and is more suited to the UK climate.
I'd try Guy at Opie Oils if you want some good, sound advice.
Magnatec is awful awful oil. Makes a very noisy engine. Use Millers 10w40, brilliant. Standard toyota filter does that job fine. Make sure you replace the sump plug washer too.
valvoline or millers 5w30 fully synthetic so long as your engine has never had mineral oil in
