Rev1/2 Rear Panel
John R
you have to use the lever on the floor in the cabin.
I've got a ribbed one at home if ya want something different ..
Aftermarket rear panels for the rev1/2 arnt fixed in so all you do is lift it up and you have access to the lock.
It just slides in a groove behind the lights.
I'm in the process of making one with MR2 in raised letters in the middle.
Russ
What a :censor: ,
You have to open the boot to lift the panel out.
Forget what i said, I'm not thinking right
:wacko::wacko:
This is all a bit of a bugger if your lever in the cabin no longer works - doh must fix it!! :)
My rear panel has raised letters... I've seen many with nothing os simply a sticker on them. Curious as to why my one has raised letters ?? Did someone do this when they originally had it on their car? Or is it norm ??
