2 Question From An Italy Fiend
yarisd4d
Hello to all , I have a new yaris d4d and 2 questions for you .
1) what is the procedure to remove the radio? ( I need to connect the mute wire
of my hand-free cellular phone to the yaris's radio)
2) where is located the buzzer that play sound when open the door with the light on ?
( I want to improve the volume )
By to all
Thanks !
:hokus-pokus:
- Remove the two dials on the centre console, there are 3, remove the first and the 3rd. These come off if u pull them towards you.
- You'll find two screws underneath them, unscrew them.
- Once the screws are off the centre console should be abole to be pulled off.
- Unplug the wires which connect to the console.
- Once the centre console is removed then you can see the two top screws which hold the radio in place. Remove these.
- There are two more screws holding the radio in place. These can be found by removing the ash tray. Once these are off the rado should be able to slide out.
as for (2) if you find it tell me cos i HATE the annoying beeping sound it makes when i put my car in reverse!! :censor: :ffs:
theres alot of posts dealing with yaris radio installations in the workshop section....if this aint good enough take a look through there :D
good luck :thumbsup:
i dont think you can do that on the standard radio, these no wire
Ciao D4D sei iscritto nel sito dello Yaris Club Italia?
Questo sito inglese e' davvero interessante c'e' un po' di tutto e poi gli inglesi sono piu' socievoli dei tedeschi. Che problemi hai con l'autoradio?
:D
Ok thanks to all !
Yesterday evening after dinner I've started remove the radio from my yasis dashboard following
your instructions .
To be honest my yaris it's a '03 type , the last one , so the proceduring to remove the radio it's slight different; there is an extra screw just on the top of the centre console below the plastic collar around the display .
After that all operations are the same .
Yes it's possible to mute the radio by a relay ,
Grazie anche all'amico Italiano .
Bye Bye.
A four relay chanels ? Maybe yes maybe not .
A single relay to swicth off the radio ?
For Italian friend ..
Non sono inscritto al sito italiano perchè quando mi collego
puntualmente mi sbatte fuori .
Bye !
the std yaris stereo should have a mute cos you can have incar kits fitted by toyota themselves
ask a guy called yaristpot although hes not around much lately!
:thumbsup:
mute = to make something silent
cos = shorthand for the word because
incar kit = a device for the car eg the thing you plug you phone in when it is in the car
sorry yarisd4d
forgot you was from italy i would have spoke a bit better english
sorry again
:thumbsup:
