Vsc
Jyrka
Hi.
Can somebody help me?
Are there any possibilities to put the switch to switch off the VSC or to reprogramm it, because it really s.... on gravel and especially on ice.
erm.. yes and no.
Yes VSC is a form of traction control, however, normal TRC simply detects a 'slipping wheel', and restricts the power output from the engine to compensate.
VSC however, combines the TRC and ABS, and can limit the power to a particular wheel/axle, and can also brake and individual wheel...
2003 year Yaris TSport have both TRC and also VSC.
Problem is that VSC brakes individual wheel to avoid side slipping and it brakes too much so you loose the speed. :ffs:
I'm sure it's got it's own dedicated fuse....locate it..and remove it.. but then I'd imagine you'd have a warning light in your face all the time...don't have much info on your model.
One thing to be aware of though...disable a safety feature...if you have an accident, your insurance may refuse to pay out...worse still if you end up killing someone in an accident say, and it's found that you have disabled it, then you could be up for man slaughter. Harsh but true.
Vipes.
Thats why i want to get rid of VSC
I've got it on my Celica.
The one thing i don't like is sometimes it kicks in and helps you and other times it doesn't do a thing??
Does anyone know if TRC can be bought as an opptional extra for a 2002 Yaris T-Sport??
Cheers :thumbsup:
Tom!!
hi
i've recently brought a 2003 t-sport but mine doesn't seem to have TRC. it slips quite a lot under heavy acceleration. surely TRC should get rid of this????
i've heaqrd that its selectable on the new corolla t-sport but not sure how true this is....
hi
On the Corolla, TRC doesn't eliminate wheelspin completely. You
don't really want to, because then you wouldn't know that the tyres
were on the limit. It's also the case that you get maximum traction with
a little bit of wheelspin.
What usually happens (depends on road conditions of course) is that
you release the clutch and there is a short screech from the tyres at
first then a few seconds of duh-duh-duh-duh as the TRC tries to
maximise traction. Even on a dry road, you can often get a bit of
intervention from the TRC at over 6200rpm in first, or when changing
gears at full throttle. That might be why you get the option to turn
it off, but I doubt you could get a faster start overall without it.
The VSC on the Corolla is always supposed to be on. There might be
a fuse, but I've never felt the need to remove it. VSC sort of works with
ABS, but it has added sensors to detect the turning motion of the
vehicle. As I understand the Toyota system, it monitors the rotational
speed of each wheel, the amount of turn on the steering column, the
speed of the vehicle and the yaw rate from a special yaw sensor.
If these don't add up, for example if the yaw rate is too low for the
speed of the car and the amount of lock on the front wheels, it
decides that the car is understeering and applies the rear brakes
to bring more grip to the front wheels.
If the yaw rate is too high and the car is oversteering then the
brake force is applied to the outside front wheel in order to bring
the back end into line.
All the time you have also got ABS to make sure that none of the
wheels which the VSC is using to straighten the car locks up and
becomes useless.
The system generally works pretty well, but it isn't a get out of jail
for free card. The laws of physics still apply and if pushed hard
enough you can go past it's limit, even in the dry. I presume also
that it isn't much help if you get into a four-wheel drift on a
slippery surface.
I didn't realise they had fitted VSC to the Yaris. The VSC was a major
plus point for the CTS over the YTS when I was deciding which one
to buy.
Cheers
Paul.
  • 5 weeks later...
Hi.
-15°C, ice, snow ajeee finally I can have some fun with my TSport :thumbsup:.
My local Toyota dealer put the switch to switch off and on Vehicle Stability Control, ABS and TRC.
Is there summut wrong, I was wheel spinning, than I had to brake cos there was no road left, but I couldnt press the brakes, the pedal wouldnt move
