Engines
Smiley
:help: 1.6, '01 avensis was running but had engine trouble.
Fitted import 1.6, '01 corolla engine with all avensis engine sensors.
Will not start.
Corolla engine bought as running, perfect condition.
Where do I start?
Does it turn over? Are there sparks?
There could be so many possible explanations with the info you have gave us. Please try to elaborate. The best place to look is for the main signs of an attempt to run, i.e what I said above.
If the engine is a direct replacement, and was running before, and the avensis engine was running prior to change, then It's probably sommat silly.
sMILEY
I've got a BRAND New Avensis (1.6) lean Burn Engine, complete with harness and ready to plug in and go, if you're interested. It's a ZERO miles unit straight from the Toyota bench test and never fitted.
Regards
