Dash Lighting...
MattMR2Turbo
You know at the bottom of the centre console you've got the heater temperature bar and the fan dial, should these be illuminated with the rest of the dash lights? Think I've got a bulb blown <_<
My bulb has gone behind the temp gauge, it's really annoying as you can't see it in the dark.
I have been told that it is easy to sort, but mine has been out for almost a year.
Can anyone help us?
Yes the temperature bar on my car lights up though sometimes it's a bit temperamental. To replace the bulb behind the temp gauge you simply need to take out the instrument cluster, not too difficult, you certainly don't need to be a master mechanic. If you look on the IMOC site http://www.imoc.co.uk/ click on the TECHNICAL then HOW TO'S you will see instrument cluster removal that will tell you all you need to know. Merry Christmas :thumbsup:
