Rear Window
wizzie12000
hi i was wondering if any one would be able to help me as im am struggling my rear hilux window works on the button in the car when i put the key in the back door it will let me go down but not up if any could help i would be grateful thanks steve
it's probably just a wire come off the microswitch inside the tailgate(or maybe the switch itself has gone south),connected to your lock barrel. While you're in there,i'd advise you to grease the runners for the window as they are notorious for shearing the vulcanised rubber mount from the window motor. just an idea. Gary
