Tyres Again
wattyg
ok. kzn 130. have 1.5" body lift. 4" suspension lift. wide arch model. 15" wheels. was thinking of getting 33/12.50x15 tyres. BUT would 35/12.50x15 tyres fit an do ok? was looking at maxxis or maybe kl71 khumo. any help would be great and would help when im pulling disco`s outta the mud. hehe
35"s should fit under the arches OK with that amount of lift but it depends on the back spacing, or off-set of the wheels wether the fronts will rub or not on full lock..
You'll need 10" wide rims for those tyres to fit correctly BTW, 8" wide minimum for 33"s. Standard rims are 7".
