Sign in to follow this
gwilphil
Oil Maint Now
Help "Oil MAINT NOW" has come up on the dash of my Rav, it is not due for a service. If I top up the Oil will it go away???
Share this post
Link to post
Don't think it is an Oil level problem, I think it thinks the Oil is a bit sooty, i.e. it needs a service.
This should reset it (i.e. normally do this after the Oil has been changed - Dealer should normally do it):
Set the multi-information display to TRIP A.
Turn the ignition switch off.
Press and hold the ODO / TRIP switch, and turn the ignition switch on (IG).
After turning the ignition switch on (IG), keep holding the switch for at least 5 seconds. The reset procedure is complete.
If that doesn't work, then it probably is Oil level. Sorry! :D.
Car Engine ECU monitors its use and if it thinks the Oil needs changing it will tell you.
Is it close to a service or have you been doing a lot of short or stop/start trips?
EDIT: Yep, just double checked, "Oil MAINT NOW" is the Oil change message.
Share this post
Link to post
Don't think it is an oil level problem, I think it thinks the oil is a bit sooty, i.e. it needs a service.
This should reset it:
If that doesn't work, then it probably is oil level. Sorry! :D.
Car Engine ECU monitors its use and if it thinks the oil needs changing it will tell you.
Thanks for that.It is not close to service but I have been doing i lot of stop starts and the Oil needs a top up
Share this post
Link to post
OK, makes sense with a lot of stop/start - Oil life gets shortened. It's telling you you need an Oil change.
EDIT: of course, if it went to the dealer for its last service, the dealer may not have done the reset for the reminder and that is why it is showing up now :rolleyes:
Share this post
Link to post
OK, makes sense with a lot of stop/start - oil life gets shortened. It's telling you you need an oil change.
Hi I was told today by my Toyota dealer that the "Oil maint now" came on was because the car had gone over 20,000 miles and not that it neaded an Oil chainge. Happy New Year to all. Gwil
Share this post
Link to post
This is from the factory manual:
An Oil maintenance management system is used. This system determines the deterioration conditions of
the engine Oil and Oil filter, and illuminates the master warning light and engine Oil change reminder light
to inform the driver when the engine Oil and the Oil filter must be changed. Accordingly, the maintenance
intervals (30,000 km maximum) that correspond to the actual deterioration conditions of the engine Oil
and Oil filter have been realized.
This system indirectly determines the deterioration of the engine Oil and Oil filter based on the
information provided by the engine ECU
This system determines the deterioration of the engine Oil and Oil filter in accordance with the soot volume
in the engine Oil and Oil filter. The engine ECU calculates the soot volume in the engine Oil in accordance
with the vehicle speed, engine speed, injection timing, injection volume, and intake air mass, and the soot
volume in the Oil filter in accordance with the engine speed and injection volume. When the calculated value
of the soot volume exceeds a predetermined value, the engine ECU will illuminate the master warning light
and engine Oil change reminder light. Thus, this system informs the driver that the engine Oil and the Oil
In addition to controlling the illumination of the master warning light and engine Oil change reminder
light by counting the soot volume, the engine ECU illuminates the master warning light and engine Oil
change reminder light when the vehicle’s driven distance reaches 30,000 km. Thus, this function
enhances the reliability of the system.
The accumulated mileage/kilometrage memorized in the engine ECU can be reset by the following
procedures..................................
You can probably take 30,000 km as 20K miles (it may even be programmed up as a 10k interval?) for UK models. The way I read it you can effectively perceive it at it as a hidden mileage "trip", who's count gets modified slightly depending on vehicle use and should therefore be reset after every Oil change.
I've certainly used the above reset procedure after every Oil change, and have not seen the message yet.
Yes, your dealer is possibly strictly correct, it was due to going through 20k miles, but did he fail to reset the count whenever the vehicle was serviced last and that is really why it has appeared? Perhaps it does come on a 20k, 40k etc regardless? Seems a bit illogical to me in that case, as if you'd just had a service at slightly less than 20k, why worry the customer by bringing up a message just slightly later when you could prevent it?
I assume you are out of step with 10k interval services, because 20k is an Oil change point otherwise.
Just out of curiosity, anybody seen the message around the 10k miles point (or 30k, 50k etc)?
Share this post
Link to post
I service my own (regularly change the Oil in addition at not more than 5k) and despite never cancelling the Oil service indicator it has never yet come on. Maybe the dealer has done it during warranty work?
Cheers
Share this post
Link to post
Loading...
