Toyota Altezza/Lexus Is200 DRIFT Car.
Monster-Mat
Oh giddy up.......mr parcelforce has just arrived..only been waiting for this parcel for 13 weeks
Hmm, seems kinda light, and small for what ive ordered......and i didnt order anything from RAYS
ahha.....the rest is coming in a second shipment
however here we have.....
The aluminium Differential mounts
And the BORIS FACTORY final drive pinion gear set (5.125)
HKS Oil Cooler set
still awaiting to arrive.....
TRD engine and gearbox mounts
TRUST high capacity baffled racing oil sump
OGURA clutch and Ultralight flywheel (ORC)
  • Replies 138
  • Created
  • Last Reply
Top Posters In This Topic
  • Monster-Mat
    71
  • knightrider
    8
  • Karma Supra
    5
  • Fidgits
    4
another part arrived today......
and a very crucial part,...................
The fuel pressure Guage
did some more Dirty work, Today i started the strip down of the Subframe
and in bits
and stripped the old paint out the engine bay, and gave it a new lick of paint
From what ive seen of the work you have been doing its going to be some car when it's done
well spent the day doing some work on the dash, after Trimming it down, and removing the parts of the vent system that wont be required, i started having a look at mounting some of the gauges..., i wanted to use the original area for a more factory look, so in the binacle ive mounted the Tachometer, fuel pressure gauge and the fuel level gauge, i still have to mount.....somewhere.....Boost, oil temp, oil pressure, Volt meter, water temp, and the lcd display for EGT.......
here are the 3 binacle mounted Gauges
also made up the bracket, and mounted the oil pots...for the brakes and clutch
and test fitted the HKS oil cooler, some modification was and still is needed, i want to make more sturdy mounting points, im also thinking of mounting a small fan on the cooler for when the car is static after a hard run
so last night i was working.......or supposed to be, well i was "in work" so that counts
did a bit more on the instruments.....
blacked out the aluminium panel and fitted the boost guage (fitted in the drivers vent)
Fitted the shift light (top of the console) and the adjuster knob for the brake bias (Red Knob)
dash is trimmed down in preperation for the new centre console
Rather than paying 50 million to have TRD bushes fitted i have used an old "racers" trick, of filling the bushes with RTV sealent
Just starting to fill one of the bushes.
Same bush filled
and the subframe, with all bushes filled with RTV
no....glad you pointed that out :rolleyes:
off course i can you plumb ;)
so there i was............working nights again.....(or supposed to be)
Thought i would have a go at replacing the rubber diff mounts for the aluminum solid diff mounts
Old Diff mounts in subframe
Old diff mounts..........out of subframe
new diff mounts, in nice painted subframe
next i had a go at setting up the V-mount configuration for the radiator and intercooler, this took bloomin ages!!
Front, bonnet down
front, bonnet up
Top view
Rear view
Side view
now im happy with the location i need to modify the radiator filler, and inlet / outlet pipes
and start to make up the brackets to hold it all into place, the intercooler inlet/outlets need changing aswell........time to crank up the TIG machine
just had a delivery by Fedex......
my pipes to make my turbo manifold
i think i may have ordered 2 much, however better to have too nuch than not enough
The custom collector...inside
and outside
i have the head flange, now i have the pipes and collector, i ven have the turbo flange........soon i can start making the manifold :)
today been removing sound deadening, and repaining the floor pan....
starting to look good......
wow, i'm just sitting here with my mouth open....really admire the work you do on this car!
if you're gonna do it, do it proper! :thumbsup:
not much has happened the last week......
today ive boxed in the lower rear arms, this will make them significantly stronger
and a nice lick of paint
well today some bits were done to both drift lex....
The inside
Both lex in workshop
The fuel system, awaiting fuel lines
Fibreglass bonnet (3.1 kilo)
Spoilerless bootlid, New rear bumper skirt
Both lex again....
Swap shop.......changing of a few body panels around
how many lex's you got?
who made the fiberglass bonnet?
i have 2, the black one is the second Team car
the bonnet was made in japan
  • 5 weeks later...
Monster-Mat; i'm here in beautiful Barbados, West Indies admiring your work. I think u are doing a wonderful job, just sorry i can't come to your hometown to see your job. U hve to keep us posted on the improvements. Best regards. I hve just bought an Altezza GXE10, and really enjoying it.
hi derrick, thanks, at the moment not much is happeneing due to work, but shortly things will be moving on again :thumbsup:
  • 4 weeks later...
took the monster to Rockingham....to see how well it would drift................
See here
more testing required :yes:
Nice one Mat :thumbsup:
good smoke :D
practise makes purfect mate....good to see your doing the victory donuts :D
Are you doing 18th at silverstone ?
i'm there hope to see you too :yes:
kimi x
lmao at the first comment though! :lol:
good smoke :D
kimi x
18th.......??? whats that
:D
