Which Bigger Rear Wiper?
jim shady
So I got this one and it doesnt fit!!!
http://www.wiperblades.co.uk/product-detai...on=4&ID=126
The clip on the Aygo rear wiper arm is too small to clip onto the new wiper support and I busted the lower part of the clip on the arm off!
Now I need a new wiper blade and a replacement arm.
Anyone got a 16" flat rear blade that fits? Where did you get it?
Thanks in advance for any help.
You need a Halfords "W22" Rear wiper blade.
I have one, fits perfectly.
Ian.
Cheers Ian, I'll pop down to my local Halfrauds tomorrow and pick one up.
Ooops. Just read your question again.....properly.
The W22 wiper is not a flat blade, it is the same shape as the factory one, just longer.
Ian.
Might end up having to settle for a standard wiper as the search for a suitable flat one is getting nowhere.
I happen to have a 40cm (16") flatblade installed in the rear, but
this required quite some modifications to the blade to make it fit.
Only reason I did do it is that I had the blade laying about useless
and I needed a new rear blade. I had to trim off some material around
the center pivot to make it accept the clip on the arm and I also trimmed
down the little flap that originally covered the hinge on the bade.
Last thing I had to do was because of the letering beneath my 3rd brakelight:
I trimmed about an inch worth of blade from one side so it would clear the letters.
On cars without this lettering 16" should fit without problems.
I got this one off eBay, just do a search for retrofit 16" flatblade. I had to take the centre surround off the arm where the normal front wiper arm attaches, but then it just clipped on.
I've done the same. I got my flat wiper blade from Tescos for £4. Unfortunately, Tesco don't stock the 26" blade needed for the front of the Aygo
