My Norwegen G6r
EXS
hi guys :) time for an update....
been considering painting the part under the ligths red agan to balance out the black/red ratio
here is a picture i modded in....... MSpaint :?
what do you think? (old pic) but you get the general idea
have also started relocating the Battery to the trunk for a little better weigth distrubusion
the new placment
  • Replies 176
  • Created
  • Last Reply
Top Posters In This Topic
  • EXS
    80
  • PaulinhoT
    25
  • Steven252
    14
  • KPARRIS-JONES
    12
Not bad at all!
Looks good - but I think it'd look better with the front bumper how it was before with just the centre lip painted black, and maybe paint the inside of that middle section too if that makes sense? Just the centre bit of the bumper black, black grill, black bonnet and black roof would look ace!
With regard to weight reduction - you should scrape off all the sticky noise reduction stuff - you'd be surprised how much it all weighs!
:thumbsup:
The Corolla looks great, can you tell me a little bit more about your suspension set up, as well as the front and rear chassis braces.. as I can't find any for my E11.
Many thanks
Wow, totaly like the new stuff you did
I was considering doing same to mine, making it two seater and race it on the track
but it has so much sentimental value for me and my fiance and be able to drive it
with my baby in the back makes the car so assom!
´o, yea Im driving it, I finished it couple of wheeks ago :D
check my thread, Im posting video of it hopefully next wheekend :yahoo:
Many thanks
hi :) i`m running yellow konis on the hardest settings and 40/40mm cobra lovering springs,and 205/45-17 rubber... but 15"would probarly do a better job.... the front chassis brace is stock but i made a small modification to it by welding a strut betveen the dampingtowers to give it some ekstra stiffnes
in the rear it`s all custum work, i have 2 separate braces, one that stiffen up the dampingtowers and one that stiffens up the whole rear coupe
here i just used some piping i found, mesured alot and velded it solid, you will have to cut into the interior to make this last mod work dough
can dig up some more info about the job if you need it:)
exuse my bad english....
Cheers
thanx mate :D
keep in mind that i only use this car in the summertime as a "sunday" driver so i dont need it to be pracktical ;)
congrats on getting your awsome g6 on the road again :D i`ll be shure to look up your tread
Thanks for the information :thumbsup: I'm looking to spend a few thousand on modifing my E11 SR, not sure which route to take at the moment. My original plans were 4x4 big power route, but that seems to be way out of my budget :unsure: so I will look at other options.
Your car has giving me some great ideas, many thanks
new updates coming soon :)
- poly bushes in the swaybars
- re-paintet boot
- new fluids :P Redline motoroil and gear oil
- desert pan in aluminium under engine (defuser)
-i will maybe bee cutting out the rear wheel vell for weigth reductions purposes end replasing it with an alu plate
-the rims will be cleer coated
thats about it for this time because the economy is stopping me
oh... and i have decided to go with the black front as is... it`s kinda the cars trademark :P
cheers mates:)
adding a random pic of the car as it stand to this day in the garage on wheeldollys all dusty and un washed :P
i also fixed the big gap i had between the hood and the middle grill
before:
after:
Its been an interesting read, I like the wing mirrors a lot, and will order some for mine very soon :thumbsup:
hi... time for a small update :D
undertray mod under construction.... hoping this mod will reduce drag a little bit and also reduce the lift effect that most cars suffer from when doing high speeds, been a b**ch to make this part fit properly :ffs: and not looking forvard to aliging the bolt holes, alotta work for a part that wont even be visible when its done
using aluminium for this part
Damn it!! you beet me to it :crybaby:
I had that in mind and a fuser in the rear also but done in glassfiber.
Will you have it sticking out from your bumper?
Tell us how it handles when its done and tested :lol:
you snooze u loose :)
it will not stick out from but run flush with the bumper
i`ll be shure to give you some feedback when it`s done
new engine in house :thumbsup: the 1zz-fe.... but it does not run sadly... but im gonna pick of the injectors manifoil and throttlebody and put the on my 3zz-fe
and fix up the new engine when i get the money to do a proper job on it
all of these parts are a fair bit larger and more optimized for power than the ones sitting in my current engine...
manifoil: bigger "spacers" and holds more volume than the 3zz one, but will bolt straigt on (the only diffrence between the 1zz and 3zz is a longer stroke)
trottlebody: 3zz: 55mm 1zz: 70mm
injectors: 3zz: 180cc 1zz: 240 or 260cc (not quite shure)
seen this done before with positve results :D
Ohh nice man!!
Will be waching this thread with both eyes now :blink:
What you going to do with those 1zz coils?? :rolleyes:
Sell em?
Ohh nice man!!
Sell em?
well.... i migth sell them if they are the same as the 3zz coils ;)
Longer and thinner runners improves low end power and reduces high end :P
Hence why Massive ITB Bell mouths give rather shite low end power.
Which one did you use in the end?
KP
first test drive done :) and looks like i`ve lost bottom end power but gained some at the hi-end of the revs.... working on a better power curve :)
the under splitter is also done and installed:)
adding some pic`s of the first wash of the year :thumbsup:
