Wheel Alignment + Tracking
Nash
I've just the suspension lowered on my yaris, now I want wheel alignment and tracking done but because my alloys are 17" TSW rib the spokes stick out too much for the garage to check the tracking/wheel alignment.
If i put my original 15" wheels back on and get the wheel alignment and tracking done would there be any effect after putting my 17" wheels back on? :unsure:
hi
got a link that gives the calcs the tyre size against another size and height is .5" radius than the standard as you should have the same offset 4 100 on a 195/40/17 then the wheel should fit correctly therefor when the oe are put back on then only the height is affected not the alignment at a guess better than state they are in now as having the springs fitted it will be wayout.
http://www.miata.net/garage/tirecalc.html
dont quote me on this as i failed maths at school...
