Mr2 Temp Gauge
speednow69
Just got my mr2 back from the shop cuz I needed a new clutch, but ever since I got it the temp gauge doesn't even move a smidgen from the "C". I'm about to take it back to get them to fix it but I was just curious if anybody knew anything I could check out. I have no clue where the wiring for it is in the engine, which is a 5S-FE. Any help is greatly appreciated, thx.
Check also that they put the connector back on the sender, its at the gearbox end of the engine so they may have disturbed it when they took the gearbox out to change the clutch
