Windscreen Replacement Cost ?
bothwell_buyer
Well - 12 miles on the road after a spell getting the new turbo engine fitted then I get a chip on the windscreen. Size of a spider flattened (so whats the size of a flat spider I hear you ask?)
Fits under a pound coin....just.
Autowindscreens do the SAGA insurance jobs and charge £75 excess if a new screens needed. In this case, the screen is not scratched and apart from needing cleaned inside, would show no benefit to a new screen.
So I searched the web and came up with the price of a new screen in NZ as £68.41....add on the fitting cost and I suppose the excess is cheaper, but not that much cheaper!! :censor: :censor:
If the guy manages to glue/weld or whatever they do to capture the problem, then I think its done free, but not sure. However, the seals up the sides of the screen aren't right so it might be worth getting a new one put in....
for interest, anyone know the cost of a screen - its for the 4.1 series of course with a green tinge ? :crybaby:
Ah mean - £75 !! Thats the cost of almost 2 tank fulls !
They are currently offering free repairs to chipped screens which I guess is a joint venture with the insurance companies.
http://www.autoglass.co.uk/?ins=goo
Thancs ancs (I spent a long time figuring out a reply)
The saga policy uses autowindscreens - but theres an autoglass just 2 minutes along the road so I might drop in there today for an opinion - I think its just gone beyond fixing (truth = I fancy not having to clean the inside of the screen for a bit).
bad news - the crack has already been done with resin and its obviously failed. These free 'fixes'must only be a temporary measure.....I guess the stress that the windscreen takes in keeping the 4.1 bodyshell rigid was just too much...or was it cos I was trying out the 3SGTE fited into it? I wonder. :unsure:
So its a new windscreen - no point in polishing this one then! I've asked them to fit a new seal/trim as the existing one is coming away from both vertical sides.
The genuine article is £134 plus VAT and the seal is £62.55 :eek: Mind you I can deliver one last Sunday :wacko:
Kingo :thumbsup:
Kingo :thumbsup:
?Fitted? :rolleyes:
