Toyota Aygo Custom-made Backbox
Paul Gi
I have decided that the exhaust is a bit much for me as i use the car as a daily driver and the noise is now getting to me - it sounds great however i no longer want this item on my car
I am selling under the impression that i will be exchanging this for someone else's standard backbox - i'm aiming for a quiet car again!
Looking for £100 ono for this in exchange for a standard backbox
Only current-ish picture i have is in the registry however just in case you haven't seen it, below is the link
My Backbox
Either PM me here, email me at tallpaul86@sky.com or text me on 07590217389
  • 4 months later...
BUMP for this
I'm now needing rid of this thing as it's taking up space in my garage
Will post an up to date picture in a bit - you will need to utilize the existing exhaust clamp but otherwise it blts onto the standard centre pipe no problem
£75 delivered or £60 if you want to collect (if you stay within a reasonable distance to Falkirk)
usual contact details above for contact
Is there anywhere local that could change the exhaust over?
I take it you still require the standard back box also?
To be honest its very easy to fit yourself however if you want a local garage then you'd have to look up the local directory.
And no I don't need the standard backbox anymore as I got one :-)
  • 4 weeks later...
