Corolla Window Tinting
corolla19
Hi
I am thinking about tinting my rolla's windows. :help::help::help:
do i need to remove the door panels to get the film to the end of the window, or is there any other method to get the film beneath the concealed seal?
any un/successful experiences ? :group-cuddles:
thanks
rolla19
i had mine done profesionally and i no that they took the windows out, i think its the only way with out making a bodge job
had to remove the door panels, its the best way
I agree.
It might be worth having a look at this thread about new legislation regarding tints. After you've read it you might think again about getting it done.
Cheap way, have done this myself once, best is to take some dishwashing soap and mix in in a bottle with water.
Wash your windows clean and nice!!!!
Take paper and mark your windows size and stuff.
cut out film bigger than the cut out, but same shape.
Spray mixture on windows and apply film, the mixture helps you move it whilst you aim on the windows (believe me this works)
then cut of extra pieces, and use rubber squeege (or what ever the spelling might be) to clear water underneath.
This prevents bubbles from forming.
TAKE YOUR TIME!!!!! this takes about 6 hours for the entire car. DON'T wind down the windows for atleast 72hours.
If your in RSA, go to www.titaniumtint.co.za
They use titanium and break it down to molecules and bond it with your windows, looks SEXY!!! cost the same as maintanance on a s*x chick!!!
:thumbsup:
I thought the thing with DIY film (pos only cheap films) was that if turn on your heated rear screen bad things happen to the film, ie it bubbles and melts???
If you really have the time and want to do it good, yes, I would advice it, other wise just remove the rubber and
cut the film as low as possible, when you put the rubber back you cant see the cut.
The thing with the rear windows and the heat wire, if you have real cheap thin tint, yes it will melt.
Pay the extra bucs per roll and get quality.
But surely the wires at the rear window dont get that hot to they? They never really do feel hot when I touch them, just warm enough to clear the mist off the window.....
I thought that self stick on stuff had been banned in that new legislation on tinting that came out last week.
I have done a few
on some mates cars works ok just dont buy the cheapest film
out there they tend to melt and scratch really easy
but simple to do, use a soft
squeege
or it will scratch, if you do get bubbles that wont come out best to
wait until get a bit dry,
only problem you might have is getting the film below the water
seal on the door its a bit tricky that is why you remove the panels
if done right looks as good as pro
