Piper Cams Stage2 Monkey....?
I know someone with stage 3s, Best advice i can give you is that they are a waste of money unless going on with a NA build. For the supercharger you have i would recommend the SP upgrade, Grab some other bits from monkey wrench racing tho.
Stick with working on the charger, if not get PFC and map it. Why not get an exhaust system and a header, Port the inlet manifold aswell for the meantime.
