Oil Sandwich Plate?
b1gpkr001
Hi all just a quick question any one know what size sandwich plate is need for a tsport oil filter as i want to fit oil pressure gauge and temp gauge.
Is it worth running an oil cooler in the summer or could this effect lift?
if i did run a cooler would it be a good idea to fit a trv?
not sure? anyone know?
Are you sure?
It talks about an oil cooler in the repair manual I have......
Are you sure?
Yeah I'm sure, I work at Toyota and I just had a new one fitted to my Compressor dude!
:huh:
How come it appears in the parts catalogue (P/N 15710-88610) and a pre compressor era repair manual?
:huh:
Honestly they dont have one dude...
This sandwich plate will fit your car:
http://prosportgauges.com/oil-filter-adaptor-plate.aspx
The senders for a lot of gauges have NPT threads so you HAVE TO remember to use nylon tape on the threads of the senders before you mount them. If not it'll be leaking like a *******
If you're in a reading mood, here's some info om my install: http://www.corollatsport.net/CorollaTSport...ges/Gauges.html
