Can I Use This Oil On My D4d
wuly1554
got 10 litres off this in my garage was wondering if i could use it on my 2001 2.0 d4d
Castrol gtx diesel
10w-40 b3
sae 10w-40;api cf
vw 505 00;mb approval 229.1
thanks
castrol gtx diesel
10w-40 b3
sae 10w-40;api cf
thanks
hello mate
yes you can use it without doubts.
all particulars of this oil are the followiing:
Applications
Castrol GTX 10W-40 is a mineral engine oil and this viscosity of engine oil is widely recommended for a variety of
engines manufactured since 1990.
Specifications / Performance
ACEA A3/B3
API SL/CF
MB 229.1
VW 505 00
Test Method(s) Unit Typical
--Density @ 15C,Relative ASTM D4052 -------0.875
--Appearance Visual Clear & Bright Amber Liquid
--Viscosity, Kinematic 100C ASTM D445 mm²/s ------14.5
--Viscosity, Kinematic 40C ASTM D445 mm²/s -------100
--Viscosity Index ASTM D2270 ---------149
--Viscosity, CCS -25C ------------(10W)
--ASTM D5293 cP 7000 max
--Flash Point, PMCC ASTM D93 °C ----------194
--Ash, Sulphated ASTM D874 % wt ----------1.05
--Total Base Number, TBN ASTM D2896 mg KOH/g-------- 8
Good luck
Igor
castrol gtx diesel
10w-40 b3
sae 10w-40;api cf
thanks
i use toyota s 5w 30w in my 2.0 d4d the only oil worth using...
