Avensis 03-09 15" Steel Wheels
Yaumeister
Did any trim of the last gen Avensis (03-09) come with 15" steel wheels, or is 16" the smallest they ever came with?
Would someone confirm if either the 15" or 16" steel wheels are of the following spec:-
15/16 X 6J
Offset 45
PCD 5X100
Bore 54.1
If they ever came with 15", what is the tyre size?
From what I can see Mark, yes they did have 15's - tyre size I believe would be 205/65/15
Maybe worth having a word with Tony @ WIM and he will probably be able to tell you for definite on the size needed :thumbsup:
Thanks for the info Janey.
It's a bit of an odd one since I am not exactly looking for steel wheels to fit on an Avensis but on a Prius, strange I know but doing some research on what is the smallest/skinniest wheels/tyres that can be fitted for winter use, and choosing steel rather then alloys due to cost.
The US Prius have 15" alloys of following specs, so trying to identify whether the Avensis has steel wheels of the same, since the offset, pcd and bore matches.
15 X 6J
Offset 45
PCD 5X100
Bore 54.1
If anyone who has the last gen Avensis and confirm, much appreciated since all I can seem to find on the net for specs on a T2 (lowest trim) still seem to have 16" steel wheels.
