Dash
John R
theres a big support bar from one side to the other, there is some room but not loads it all depends on what youve got planned.
I'm pulling a dash off some time this week, we just had a car in to break, i'll post some photos if you like - I can tell you now theres not a lot of room, i couldn't believe the amount of crap they managed to fit behind the dash when I first took one off - those crazzy !Removed!!! Its mainly to do with the climate control stuff - 4 or 5 large white plastic housings and lots of little electronic boxes. There is also the bulk of the interior wiring loom which is fairly comlicated - I wouldn't recomend going at it with a jig saw in situe, its not too complicated to remove.
Matt.
Do they put any of and Ait Con components behind the passenger side? I only ask because it's where the fans and chiller radiator (don't know the correct names) are placed on a Range Rover.
