All Activity
- Past hour
Maria Garcia joined the community
Prize
Frankie baby joined the community
Looking for a yaris clean no hidden bumpz
Jimota replied to dads Taxi x3's topic in Yaris & Yaris Cross Club
Walk away. -
Nobel (Alfred).
bathtub tom replied to dads Taxi x3's topic in Yaris & Yaris Cross Club
That suggests to me he's hiding something. -
Gelignite
Hi Tiago, The VSS sensor is typically located on the driver's side of the transmission case in your car. a repair manual can provide specific visuals.. A faulty or dirty VSS sensor can trigger this code. Check the wiring harness near the sensor for any visible damage. If the wiring looks okay you can try carefully cleaning the sensor itself with electrical cleaner. If the code persists after cleaning and inspection, speak to a mechanic for diagnosis and potential replacement. P0420 Catalytic Converter this code indicates a problem with the catalytic converter system, which involves the exhaust system. Due to the potential complexity of diagnosing and repairing the exhaust system, speak to a mechanic is the best option. They can pinpoint the exact issue, whether it's the converter itself, oxygen sensors like the upstream sensor before the converter for Bank 1 in your car, or exhaust leaks. Brake vibration,warped brake rotors are a common culprit for brake vibration when cold. While replacing rotors might be a DIY project for some, it's generally recommended to have a mechanic confirm the diagnosis. They can ensure other components aren't causing the vibration and recommend a solution, resurfacing or replacing the rotors. A flashing airbag light signifies a serious malfunction in the airbag system. I would get this looked at ASAP as it's critical for safety. This requires immediate attention as soon as possible. Airbag systems are complex and require specialists to ensure your safety. Hope this helps.
Tony.s joined the community
dads Taxi x3 replied to dads Taxi x3's topic in Yaris & Yaris Cross Club
OK back to the car in question and seller turns out it's a garage not a private sale . I told him to day that I found the old add with the CAT.. N info on it and the new don't have the CAT N info on it I asked him for the information off the log book to do the hpi check he refused to give the 11 dig log book one so I can't do the check till buy the car . So I'm going to go all over the car to see if there any faults if I find any. As we not planning on selling the car the insurance said its fine so I still need to hear your info . Cheers -
This thread is of interest to me as I am seriously thinking of getting the new C-HR, so much so that I have had a conversation with the dealer. I have read numerous reviews on t'net and watched loads of YouTube videos and am nearly convinced! Does some one want to try and talk me out of it .....? 😉
It's the new type R one he's after . in royal blue i think he said or the german grey one . There £15K and I don't want to go there for insurance lol why he's going for a cheap one to build it . -
Mike 16 joined the community
2DOORS joined the community
How to permanently disable excess speed notification?
Mike 16 replied to Beefstah's topic in Rav 4 Club
I wish I had purchased the older model just got the gr sport hybrid thought i was going mad every time i turned the beep off and it came back the next day it drives me mad every time it beeps -
New Yaris design 2024 photos here !
Cyker replied to Countryside's topic in Yaris & Yaris Cross Club
Well the year will be part of the registration plate so you're sorted! -
Explosive
I had the same issue for years. Meloned is correct, attempting to remove the sensor can cause the bolt to snap so you would need to drill it out. I my case it's probably the ABS ring rather than the sensor, which is possible to replace but it's not easy. The costs for the ring is about £10 online. Costs for labor - I don't know if the garages would even take such a job on. For them is easier to replace the wheel hub assembly which comes with part warranty etc.
Sharnie70 replied to Countryside's topic in Yaris & Yaris Cross Club
It doesn’t mention year. Just. Toyota Yaris Design HSD 114.0 bhp 1490 and my registration number. - Today
Are you going for a Toyota upgraded radio with the Sat nav integrated or a aftermarket head unit that fits in the hole? If it's a aftermarket HU Then it could be a plug for plug direct replacement or a ISO loom, Toyota cabling to the ISO to the aftermarket HU. Whatever, it's a breeze to change,you can't go wrong.
Saw something today I haven’t seen for years..
FROSTYBALLS replied to Primus1's topic in General Club Discussions
Try asking Alexa 'when is the zombie apocalipse?' -
I'll unstake it, not expecting the nuts to survive so will get new ones.
No. Toyota Direct Parts are Fish Brothers, a Toyota dealer. The Official Toyota Store on eBay is Toyota GB - https://www.ebay.co.uk/str/toyotaofficialstore
Locked Out Of My Prius. Fob And Key Do Not Work!
alexk345 replied to AnthonyJV's topic in Prius Club
i bought unlock hit for 80cad from amazon to open it -
Primus1 replied to Primus1's topic in General Club Discussions
I actually met my wife whilst she was hitchhiking, she told me she was a witch, and it was true, she put her hand on my knee and I turned into a lay-by -
Hi John,If you fix the catalytic converter heat shield without a washer, you risk potential problems. The main issue would be a significant increase in rattling and noise coming from the exhaust system. The washers act as a buffer, absorbing vibrations that would otherwise cause the heat shield to bang against the exhaust pipe. Without the washers, these vibrations would be directly transmitted, creating a constant and likely louder tin can sound.The continuous rattling and contact between the heat shield and exhaust pipe could damage both components. Over time, the vibrations could wear down the metal of the heat shield and exhaust pipe, leading to holes or cracks. As mentioned earlier, the washers also help accommodate thermal expansion. Without them, the connection between the heat shield and exhaust pipe becomes more rigid. This rigidity could cause stress on the exhaust components as the system heats up and cools down during operation. In extreme cases, this stress could lead to cracked. Hope this helps.
Catalyst breaking up and causing blockage?
JERRY12 joined the community
2000 Toyota Avensis 1.6 ( 3ZZ-FE) Hello to all. Can you guys help me on my issues please I have this two codes P0500 - Speed sensor (VSS) - circuit malfunction Can you tell me where the sensor is located please? P0420 - Catalytic converter system , bank 1 - efficiency below treshold Is this the sensor before or after the Catalytic convertor? When i brake first couple of times on cold car the brakes feel like when abs engages it vibrates like the abs is engaging then behaves alright....no lights of abs on the dash My airbag light keeps flashing i have no codes i hjave check the plugs under the seats all is ok Do you have any tips on try to repair this or any ideas? Many thanks to all
