Avensis T180 Holding Back ..........
GrahamJH
Hi All,
My t180 Avensis 07' is holding back between 3,000 to 4,000 and sometimes just over 4,000 rpm. Is this a possible overboost problem or something else lol ? I did have a new egr valve fitted in December for other symptoms. Any suggestions welcomed.
Thanks.
After all I had to do a 1,000 mile oil consumption test. End result was nearly 1.5Ltrs of oil in just over 1,000 miles. A new 3/4 engine was fitted amongst a new 5th injector and ecu re-program. Thank you Toyota.
Good News
Did they explain the connection between holding back and the oil consumption issue?
  • 8 months later...
No they didn't and it's doing the holding back thing again. Annoying as it seems worse this time round...
