Iq Alloys On An Aygo
igoaygo
Hi..would 15' IQ alloys fit onto an AYGO? They both share the same bolt pattern etc? Thanks
Cant say i know for certain, but they should fit, the spec for them in 15" on After Market alloy sites are the same.
that is,
PCD 4 x 100,
offset 35 to 45
centre bore 54.1
studs N 12 x 1.5
You are going to know as soon as you try one on,
so best try before you buy if you know someone with an iQ that will let you take a wheel off.
? does your Aygo have discs or drums at the rear?
best check how the iQ wheel seats correctly if it is drums.
*i would get the wheel nuts that go with the iQ wheels you are buying,
if they are different from the ones that are on your Aygo to suit your wheels.
george
