Cold Start On My 2Ltr Petrol Vx
read
Hi all just got my rav4..quite an old one but cold starting not that good sounds like a little misfire on cranking the engine. But once it's started, it runs and start fine...any ideas,,thanx :yucky: and of course i never meant fx...VX
No problem.
BTW I've got quite a lot of grey hair growing from my ear too.
Hi Read, does yours sound the same as mine on startup? Reply to my main thread if it does and keep in contact. Especially if you find your fault before I do! Cheers, Lee
Hi LeeADAB
Yep that's it spot on...but mine takes a bit longer to fire up. it def some kind of misfire..but tonight it started normal...
it is bugging me though ..many years ago I had a ford escort which done the same and it was a mystery but real hard to start. one dark cold morning my other half was sat in the car trying to start it I had the bonnet up..then I saw it, when she tried to start it, a spark coming off the HT lead there was a small crack in it changed the lead and no more bad starts...not saying that's the RAVs problem but it could be :g:
