Tech429
Members-
88 -
First Name
David
Toyota Model
Corolla GR Sport 1.8 Hybrid
Toyota Year
2022
Location
Conwy
Tech429's Achievements
Yes I have noticed too... Should have gone for the Touring Sport with 17" wheels instead...
Trips missing from My Toyota app?
Tech429 replied to ACameron's topic in Corolla & Corolla Cross Club
This is a huge issue... Toyota are a bit lame in coming back when i contact them on this... -
Oh how true 😁
But the pads can and do stick to the discs - so best to adjust accordingly as to what you want.
It isn't difficult at all - didn't say it was - but when they put these things on why not enable them as standard? The rear wiper thing is a benefit and a safety thing first and foremost... and Toyota are supposedly market leaders so why not do what others do as standard? Yes the added features should be as standard if there but hidden until you find out about it and then get told you have to go to the dealer to get enabled (why not allow user enable via the vehicle settings? Surely this should be allowed?) It is a Company Car so was not able to do so... but going to check with Lease Company and Toyota if they will do for me 🙂 if available then why not have it? Oh so true. I just know they are there but not enabled as standard. This is bad judgement on Toyota's part. Something like this is a mere simple slide option (from disabled to enable) but not a setting that the owner can do from the Vehicle Setting of the system - the dealer must plug in a Laptop to do this. 🤷♂️
Active Cruise Control & Indicators Question
Tech429 replied to Rambler56's topic in Corolla & Corolla Cross Club
Yes I have my Tom Tom fitted in place too... and it shows 2 to 3 mph less than that. Yes acceptable in a 30, but out on the bypass or motorway the ACC is a pain to maintain. -
Struggling with MyT trip updates again.
Tech429 replied to FiestaRed's topic in Corolla & Corolla Cross Club
I have done so... even given them screen shots of where the signal was lost, etc. But they claim nothing can be done and need to drive into a good signal area. I'm 90% always in a good signal area - and it does not seem to track return journeys (and sometimes switches off halfway through a journey). -
I updated mine and until this morning my car was still 150 miles away in Birmingham! I was there on Wednesday. Go figure! -
Just to say mine not worked correctly since Easter! I contacted them and the response was "it is all to do with the DCM signal in the car - if no good signal it will not pick your car up. To rectify drive into a good clear signal area!" Really? My DCM is always at least 3 bar strength and has never gone altogether. I did tell them it is their fault and a crap app but not heard back yet. So much for customer service eh? -
Not on the hinges of tailgate - but I found out that you should check the doors as water accumulates in the doors. Open doors and if not already removed then remove the rubber plugs from the front-most of the front doors and the rear-most of the rear doors (there are 3 in each door) to allow water to drip out.
The indicators are linked as already said in other replies... Same for the Lane Guidance Assist too - if you do not indicate it will alarm that you are deviating over the lines, but if you indicate the systems goes into standby until you get into lane. Have only tried the Adaptive Cruise a few times to see what it's like - but probably will only ever use Constant Cruise as this allows for 1mph increments instead of 5mph increments (which for adaptive is bad in my opinion). Plus as all newer cars speedos are set about 2mph more than actual you feel like everyone is coming up behind you and then overtaking. -
Yes only when going down hill to prevent overuse of brakes and brake fade. It does work well too.
Not many hills there 😁 Only the Little Orme and Great Orme.
I think it was just the drivers one... did not think to ask if they were changing both. Still all quiet now 👍
My T info before collection of car
Tech429 replied to Kental's topic in Corolla & Corolla Cross Club
Also the dealer does not have to register for you - you can do this yourself by entering your reg or VIN number - the app automatically registers the vehicle to your account once created (which you do initially).
