Evaporator Drain Pipe/hole Location Please?
zulu
My AC has this musty odour for past few months.After searching the net , I bought the faom cleaner to spray onto the Evaporator.
But they advise me to insert the spray tube onto the drain hole for Evaporator.I can't find the location?any advice please? Pictures might help.
It's under the front passenger carpet towards the centre and close to the bulkhead. Underneath the car its just above the subframe , it sticks out about an inch but is akward to get to. My advice is pull the pipe up from inside and try and do it from there.
Many Thanks North East Tech .
I managed to pull the tube from inside and cleared the whole lot. My air con is odour free now.
Total money spent £4.99. Time spent 25 mins. :thumbsup:
  • 10 years later...
hi what you use to clean it i bought genuine stuff from toyota that costed £15 a toyota avensis t27. by chance dose anyone know where the evaporater drain tube is under the toyota avensis t 27 and will this stuff be ok to put in there
https://www.ebay.co.uk/itm/353168280969
