I have a slight issue with the light switch on the indicator stalk. If the switch is turn a little beyond the headlight position, the lights go out. I have taken the switch apart so far. After cleaning, moving the grease and bending the contacts, it is a little better but not perfect. I may need another control so on the look out for one with the front foglight position, for T22 Mk1 model.
