I detected slight clutch slip when accelerating in 2nd gear above 3000 rpm. The pedal is biting point is high but in normal use the pedal and clutch is okay. I spoke to my mechanic who say i have plenty of time. I will have the clutch replaced sooner than later.
I will be getting the 3 piece kit (LuK), so not skimping on the concentric slave cylinder.
The only issue is to check the clutch places cost before committing, or let my mechanic who has work on my older car do the work? How mu
