In addition to the information supplied in the owner's manual, here is some information on the vehicle jacking points for the RAV 4.2.
Please remember:
- Don't jack up a heavily loaded vehicle.
- If you're removing a heavy part (e.g. engine), the centre of gravity of the vehicle is likely to shift as you do it.
- Don't work under a vehicle just supported by the jack - it's not worth the risk.
- Use correctly placed wheel chocks if appropriate.
Above all, always follow the appropriate safety precautions.
Note: the central rear jacking position for the 4.2 is the diff carrier and not the diff itself.
The information is supplied in good faith, but TOC and any of its members accept no liability for any damage, injury or loss sustained through use of the information provided.
Please work safely.
