I currently have problem with the driver’s door window on my 2005 Yaris d4d in that when it lowers it is dropping lower in the front than the rear of the door so this makes the glass twist out of line. Can anyone please advise the possible cause of the problem and what will need to be done to solve / repair it.? Is the window regulator , motor and runners the same on Japanese built Yaris as French build one? Thanks Steve
