I have a 2014 Auris Sporting Tourer which has a creaking suspension issue. It creaks both on the nearside and offside when a the car's corners are under load, so for example going up or down multi-storey car parks and sometimes going around roundabouts
Toyota have checked the car three times now and say there is nothing wrong with the suspension but as the video below shows, there is an issue. Sadly the technician who said he watched the video yesterday wasn't the technician who worked on m
Just as an update:- I was working on another 13 plate Auris with the suspension creak. It was worse than the first one and was particularly prone to creaking whilst braking over bumps, even light braking caused it. No work had been carried out to cure this beforehand. The car had done 54,000 miles.
I sprayed silicone oil over the suspension bushes located at the front of the suspension lower arms, one on each side of the car. This improved the situation but definitely did not stop it
