What is the height of boot with a spare wheel n false boot floor as at this time the dealership is shut? In the hatchback
As a new order the option for a spare wheel must be chosen at point of order for either 1.8/2.0 Hybrid, Toyota are working on an accessory kit to fit a spare wheel into to both models. the 1.8 will be a big job as the entire boot trims set needs changing out to allow installation of the raised boot floor whereas the 2.0 already have the raised floor and only need a few new pieces of polystyrene, fittings, tools & wheel to make a kit.
Parts required for a 2.0 HB install:
Retaining b
