How To Turn Off The Seatbelt Beep ?
Raistlin
• first set the ignition ON
• set the distance counter to ODO by pressing the distance counter knob
• set the ignition OFF
• set the ignition ON again
• press the distance counter knob again for 10 seconds
• close the seatbelt and keep the distance counter knob pressed in
• the display of the distance counter will show the tekst: "b - on"
• release the distance counter knob again
• press the distance counter knob again shortly to switch between:
"b - on" and "b - off" and set it to "b - off"
• set the ignition OFF again
• modification done
After this modification the seatbelt beep is set off and you will no longer hear the seatbelt beep again.
But you can always set the seatbelt beep ON again.
Setting the seatbelt beep off will not change anything to the other safety systems in your car.
Although this modification is completely safe, I can't take any responsibility for it, use the instruction's at your own risk.
Wasn't there a topic on this already? With a whole discussion on wearing the belt instead of shutting off the sound?
Not sure, but apologies to all if it was a repost helpsmilie.gif I have my MOT tomorrow so I switched it back on and thought I'd share it. thumbsup.gif
Or you could just wear your seatbelt, like you're supposed to.
Although, while we're on the subject, don't suppose anyone knows how to turn the driver's airbag off because I'd much rather faceplant the steering wheel.
I do wear it normally,
It's just while I'm putting the car in the garage do I fracture the occasional law,
I am so busy trying not to hit bikes, tools, jetwashes and the BBQ, the noise spoils my concentration and I can't scratch my baby biggrin.gif
I think you can only turn off the passenger airbag for kiddy seat's etc.
The beep should only sound when you're going over 10mph,
a speed I normally don't achive when manouvering...
