Resetting Data "oil Change"
tavy
Resetting data "oil change" (for models with engines 1AD-FTV, 1ND-TV, 2AD-FHV and for models with optitron display) :
1. turn on the ignition (IG);
2.press the reset button, while on the odometer appears "ODO";
3.turn off the ignition;
4.hold down the reset button, turn the ignition (IG). Reset button of the trip meter button for 5 seconds until you meet the following conditions.
The message "OIL MAIN RESET" can be seen on display , and the odometer will read "000000" for 1 second .
Emergency indicator light illuminates .
When the odometer disappear, and the emergency indicator light will go out and resetting procedure is completed.
