Where Is The Microphone?
bkc
Hi everyone where is the microphone located on the avensis its for the voice recognition sat nav. Is it just a small hole or does it petrude out? Can someone please send me a photo and show me thanks.........
I think its behind the mirror glued on to the screen as mine used to keep falling off , tried all sorts of glue and the best believe it or not is UH-HU . :o
U sure? I think that might be the gps antenna or something. Have u got the flip up sat nav in colour? cause if u do then u'll def have a mic.. i think
Ohhh not sure then , I havent got the flip up sat nav just the turn by turn but I know the mike is wired in and I thought the antenna for the rasio and the sat nav is in the rear windscreen ?
The GPS receiver is mounted inside the dashboard between the satnav popup screen and the windscreen.
The microphone is the small hole in the trim around the front interior light. (not the one that glows when the lights are on)
ok thanks ;)
