Toyota Estima Problem
nathaningle
Hi, I'm new here.
I've got a problem with my Toyota Estima, 8 seater.
There's back pressure in the oil, pushing oil back out of the filler cap.
Anyone know how to solve this problem?
Thanks.
? warped cylinder head?
Wear in the cylinders ??
A compression test would probably show.
having the same issue... any progress? i just double check the oil level every now and then.. is this a big issue for estima? i havent ask anybody about this yet..
I never had an issue with "lucy" no overheating problem even with 12 people in..
I went to lucy and open it up.. i notice that there is a small hole.. that is where the oil seems to get out.. do we need to block this?
  • 2 months later...
yeah seal the hole but if the heads warped then id get a new head but you could always try skimming it see if that helps but i would just throw another head on it to be honest ?
