Lucida Leaking Fuel From The Choke
garry7000
good evening all
my m8 has lucida m reg and we have changed the cam belt and water pump because of a pump failure but now there fuel leaking from the choke, at first it was from the bottom of the choke where the two meet, now its leaking from the top i think its coming up the shaft and running down the springs, we have changed the choke but still have the same problem.
we have pumped the fuel so the filer is hard but is goes soft fast (no jokes)
any ideas before my m8 scraps it.....
thanks
have you tried changing the fuel pump? since you already have change some.. it should not affect the fuel pump..
