Radio/ Cigarette Lighter Not Working In My Toyota Corolla
radio cigarette toyota corolla
  • Please log in to reply
13 replies to this topic
#11 TechnoZir
TechnoZir
    New Member
  • Registered Member
  • 15 posts
  • First Name:Zir
  • Gender*:Male
  • Toyota Model: Corolla 2002 VVT-i
  • Year: 2002
Posted 20 April 2013 - 04:45 PM
The lighter runs just from the 15A CIG fuse.
The clock runs from the CIG and DOME fuse.
The Radio seems to run mainly from the CIG and DOME as well.
Hi
The problem was actually with fuse which I couldn’t find, above the glove box lol
I now have the radio and lighter working. But not the clock. Is it even a clock? Ive seen it on some cars by doing a google image search, but does my Toyota VVT-i T2 have
this clock? if it was a clock wouldnt it have buttons on there to change time?
Can’t even find the fuse for the “clock”
I have a clock on the radio any way, but just want the secondary clock working if one is meant to be present.
Also another issue is with this cigarette lighter holder, when I pull the lighter out the housing pulls up with it (doesn’t fully come out though) i've opened it up and had a look inside it but dont know what i could do??
Just attached a few images for you to see:
This is what i'm talking about the lighter:
when i pull it this happens:
Have something to contribute?
Sign in or register to start a topic...
Sign up to TOC Premium Membership To Remove These Ads
#12 TechnoZir
TechnoZir
    New Member
  • Registered Member
  • 15 posts
  • First Name:Zir
  • Gender*:Male
  • Year: 2002
Posted 20 April 2013 - 08:20 PM
also the aux adapter i have a feeling it wont fit my Toyota Corolla 2002 as it says 2004 onwards on that site and ebay
http://www.caraudiod...siscorolla.html
same on ebay and it says 2004 models onwards
http://cgi.ebay.co.u...em=261137592929
#13 oldcodger
oldcodger
    Guru Member
  • Registered Member
  • PipPipPipPipPipPip
  • 763 posts
  • First Name:oldcodger
  • Gender*:Male
  • Toyota Model: Corolla 1.6
  • Year: 2006
Posted 20 April 2013 - 09:29 PM
You just have to look up the right adpaters etc for your year / model, if you had decided on a radio model contact the Car Audio direct for the right fittings if they are not clearly listed on their site.
You will loose the mpg meter / display though tis not that accurate.
There are several other large online car audio sites to look at as well,
The cig lighter , looks like you will have to buy a new one, expect a after market one will fit the hole but might need the terminal wiring up.
Not sure what that lcd panel on your model is, if there are 2 or 3 switches on it then ist a clock, though it might be a int/ext temp gauge or something to do with the fans/ heating ??
A clock does run off the same CIG 15A line as the cig lighter.
You need a T2 owner to help you there as the books are useless.
Have a look at this manual, its not your exact model /year but might help with your door lock problem / diagnosis
https://dl.dropboxus...vice Manual.zip
#14 HueyDols
HueyDols
    New Member
  • Registered Member
  • 1 posts
  • First Name:Huey
  • Toyota Model: 2q
  • Year: 1990
Posted 11 August 2014 - 07:33 AM
The ecigs , looks like you will have to buy a new one, expect a after market one will fit the hole but might need the terminal wiring up.
Hello I have been dealing with similar problem and really hope your shared solution will be able to solve it..
Not what you're looking for?
Register now, we have a huge community of enthusiasts to answer any questions you might have
Also tagged with one or more of these keywords: radio, cigarette, toyota, corolla
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
