Toyota Avensis Sat Nav Display Issue
Silverman2014
Afternoon
I have a 04 plate Avensis, in the last week the sat nav display which also includes fuel information has darkened to the point now there is just a black box around the display, similar to a dodgy calcalator, if the screen remains on it does lighten up for a few seconds but then darkens again.
Rang my local Toyota service centre who would be happy to look at it and tell me the issue but I would have to pay £60 for the pleasure.
Any help would be greatly received
Hi, Welcome to the club... Enjoy :driving:
I have seen this problem on these models and its usually has one of two cures.
First, try a hard re set of the system - this entails disconnecting the cars Battery - and holding the two Battery terminals together ( not the battery- the Battery lead connectors ) Hold them together - get something to hold them for 10 mins ...then leave the battery off for a further 30 mins..
Reconnect the battery and try operating the system as normal... if the hard re set has worked , it will be ok.
If not - then s an internal problem with the unit itself - usually a problem with the chipset - but you would need to locate a radio repairers ether locally or online --and dispatch the system for repair.
