Unidentified White Connector Of An E12 Corolla
espero1
Hi there,
I would like to ask you, what could be clamped to the white connector on the right hand side of the attached photo, taken on an E12 Corolla behind the glove compartment?
Glove compartment cooling or anything else? Thank you in advance for your ideas.
the same question for the following connector near the brake oil support:
Most wiring looms had all the connectors for all models, so you find such connectors empty if your model does not have certain features.
Would think the one in the engine bay is a brake fluid low alarm or something for the carbon filter.
As for the glove box one ??
Perhaps get the spec sheets for all the models then work out what features you do not have and see if that idetifies it ..
Hello,
I have the SOL configuration, so it has already more features compared to other models.
I think, that near the glove box, it could be te glove compartment cooling?
It would be nice, if I manage to identify it, because perhaps I will be able to activate some new features?
