Removing The Lower Center Piece Of The Dashboard (09 Aygo)
West Midlander
Hi guys,
I'm in the middle of cleaning my 09 Aygo and I was wondering if it is an easy enough job to remove the plastic center piece that includes the cup holders and the gear stick. I can see one bolt connecting it just in-front of the hand break and I assume it is clipped in but just wanted to get some advice before jumping straight in.
Any help would be great,
Gareth
I've never taken my concel off but it should just be a nut and bolt job.
If you get chance get a copy of the Haynes workshop manual it cover all those sort of jobs.....halfords should have one :)
if you undo the bolt under the half moon shaped section by the handbrake it will lift out and all unclip, be gentle when you strip it out
