Gen 7 140 Vvti Pre Cats?
wafers
My father has a 2001 140 vvti Celica which had a replacement bottom end engine from Toyota a few years back due to excessive oil burning. It's run sweetly ever since.
I've recently bought a 2003 MR2 which also has the 140 vvti, which is prone to pre-cat failure, leading to terminal engine damage. Its a well-known problem with the mr2s. Fortunately, mine has had the pre-cats removed before any problem could occur.
However, I'm now wondering if, since they are essentially the same engine, the Celica 140 also has a pre-cat failure issue? I've tried googling it, but couldn't seem to come up with much.
Any ideas?
It's an issue I have never seen or heard mentioned in the Celica community....so I guess.
Neil
Neil
That's what I wondered. Obviously the exhaust setup on the MR2 is totally different, but I still thought the Celica may have precats fitted in the manifold. Anyone else know?
140 celica only has the one cat underneath, there isn't one on the manifold itself
  • 5 months later...
Is this true????....... am an owner of a 02 Avensis vvti that is always looking for a little extra go and particularly innovative ways of gaining it DIY. I know that certain Celica models cams with a 143 bhp version of the 1ZZ-FE engine as opposed to the 127 bhp we have in our 5 door hatchbacks.
From what I've read so far you have a slightly bigger bore throttle body and intake manifold, different exhaust manifold and reprogrammed ECU which makes sense.
So is it true that you have a single cat underneath on the 1ZZ-FE engined Celicas rather than the two in the exhaust manifold that we are burdened with. If this is true it goes a long way towards modifying my exhaust system, I've been bending my brain around how I would go about removing these precats without freaking my ECU out completely.I know a single underbody cat isn't like a decatted system but it gives me more scope for tweaking it plus the opportunity of fitting a decent extractor style manifold :)
I had an 2001 Avensis SR which was 147bhp I think and that used to go well loved that car had it for nearly 11 years and missed it from the day I sold it in 2012
