Problem P1349, What Could It Be?
konrad0110
Hi, ive got a T2 1.8 Petrol 2003 Avensis and ive been getting the p1349 error code, it comes on sometimes and sometimes its off (Mostly on), could anyone help me to diagnose what could it be?
Hi Konrad, a quick search comes up with
Dirty or low engine oil
Valve timing
Oil control valve
VVT controller assy
or
ECM
Del
Variable Valve Timing (VVT) system controls the intake valve timing to proper timing in response to driving condition. The Engine Control Module (ECM) controls Oil Control Valve (OCV) to make the intake valve timing properly, and, oil pressure controlled with OCV is supplied to the VVT controller, and then, VVT controller changes relative position between the camshaft and the crankshaft.
Read more: http://engine-codes.com/p1349_toyota.html#ixzz3fPnPhHCO
This is a description of the code you gave.and the things that are possible to throw the code as crofter said above.hope this helps.
Valve timing
Oil control valve
VVT controller assy
or
ECM
Del
Oil is new and FUlly topped up, could low quality oil be a problem? (i dont know whats in it as i bought it like that)
Ive also had a look at the oil control valve previously and it seems ok, any signs that could tell me its bad?
How did you find the code?have you got the Toyota diagnostic tool?
when you looked at the control valve was the filter clean as a blocked filter will throw this code.
