Decat Help 2zzge
Jonathan31391
New to forum guys some help needed with my corolla bought a spare standard exhaust want to decat it and resonator box removed how to I keep eml light off so I can drive without limp mode that's the plan much help would be appreciated ;)
In the UK removing the cat on a vehicle where one was originally fitted will be an MOT failure
I bought a spare center section including cat so gonna swap them around come MOT :) was thinking maybe gutting cat or removing but want sensors to work I don't mind trc and vsc light on or engine management light just don't want it running in limp mode cheers
Need some advice on how to keep eml light off
Have you had a look round the site? Just type in decat in the search box at the top of the page and you'll find some links including this one.Good luck
http:/www.toyotaownersclubcom/forumstopic/96535-decat-on-toyota-corolla/
Thanks been reading up now just need to find the correct exhaust spacer for lambada sensor. You dont know which one it is ? thanks for the help
Think you mean 'lambda' - a lambada is a Brazilian dance.
Yea you know where I'm coming from mate well any info to share???
