Bluetooth Stopped Working
Lakeuk
I hardly ever use the bluetooth in my 2008 aygo blue but noticed today that the light on the controller unit no longer glows and no response from the buttons, my phone can not see the bluetooth device to connect to.
Is there any trouble shooting I can do to try and pin down the issue, has the bluetooth setup got a fuse I can check.
Delete the pairing from both the car and the phone, then re-pair them.
Already unpaired on the phone, can't access the car side, no response from the bluetooth button above the rear mirror, think no power is getting to it
Looked through my bluetooth hands-free system owners manual
Hands-free system does not respond. UIM buttons not lit
— check UIM connection
— check the connection to the electronic module.
Tomorrow I'll check the wire into the User Interface Module, but where will I find the electronic module
  • 3 years later...
Mine faces the same problem....it still lights up and everything but doesn't respond to clicks and commands..I deleted the pairing from my phone but still can't get the system to respond
  • 1 year later...
hi, i have toyota aygo 2005 version. when i connect iPhone the bluetooth connects with sound, i paired with code 1234.
but then it doesn't work in the radio display.
do i have to unpair the old phone connected to the machine first?
how can I do ?
On 9/9/2020 at 8:06 PM, Dax87 said:
hi, i have toyota aygo 2005 version. when i connect iphone the bluetooth connects with sound, i paired with code 1234.
how can I do ?
On 9/9/2020 at 8:10 PM, Dax87 said:
Toyota Aygo Lettore CD Radio, Autoradio Stereo Con Aux IN , Gratis Cavo |  eBay
this is my model radio
If your car has bluetooth it is an accessory add-on as the headunit pictured does not have integrated bluetooth and cannot display anything related to the bluetooth.
how can I do ?
can you ask the radio to forget it? Most can cope with one or more bluetooth as long as they're not connected at the same time
The radio that Dax87 has doesn't support bluetooth (per the reply from Devon Aygo) - so Dax87 appears to have a bluetooth accessory added.
On 9/11/2020 at 6:21 PM, Dax87 said:
I check and update you.  if it doesn't work i will use the aux cable.  stay connected
Post a picture of your bluetooth control interface
unfortunately I can't get it to work. as soon as I can I send a video of what happens and related photos.
sorry for the delay
