Acende a luz do motor e do controle de tracao e indica verificar vsc
mario1972
This is a UK based club, and unless you can post in English, will be of limited use to you.
I used Google translater and came up with the following:  Lights such lights is a sensor ?  like this
 Switch on the light engine and the traction control and displays check vsc.
It is Portuguese, which I don't speak.
Ele é o Português , que eu não falo .
With no info on the type of engine, the symptoms is a blocked EGR of a diesel engine.
Com nenhuma informação sobre o tipo de motor , os sintomas é um EGR bloqueada de um motor diesel .
