Alarming Issue any help appreciated
MarkJC
Hi All i'm a new member and have just last week acquired a 2008 Invincible Auto which I love..Except for a little issue with the alarm .
When the doors are locked with the remote the alarm goes of after about 4-5 minutes which is slightly annoying although if I lock car manually all is quiet.
I have removed bonnet switch and cleaned and tested which seems ok.
Any thoughts? Its booked in at Toyota Cambridge on Tuesday but it would be nice if I could avoid that.
Or is there a fuse which can be pulled to disable the thing, if the remote locking worked and no alarm I'd be happy.
Hi Mark & welcome to TOC :smile:
When you lock the vehicle with the mechanical key it doesn't set the alarm.
Usually the alarm going off when unwanted is due to 1 of several possibilities - voltage drop due to a failing battery/something left on etc.,interior motion sensor triggered by a fly etc. (you can usually switch this off) or the motion sensor for the vehicle being set too sensitive & triggering for wind, passing vehicles etc.
Hi Scott Thanks for your reply and your welcome to TOC.
The Battery seems strong as a ox and I don't think i've got a fly!
Perhaps it could be a sensitivity issue how can I turn it down?
Although it seems to do it every time and its not parked on the street and or windy at moment!
best
Mark
Hello Mark - welcome to Toyota Owners Club .
Disabling the alarm may invalidate your insurance, as you would be making the vehicle less secure and more prone to theft.
